9800-cl with layer 3 svi
k. cheng
The 2nd paragraph in the “Recommendations for Wireless Management Interface” section of https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-6/config-guide/b_wl_17_6_cg/m_config-wmi.html  says to make the Wireless Management Interface on a 9800-CL WLC an SVI. How important is this recommendation? Will it affect HA? Because my 9800-CL1 (10.43.8.20) has this config and I can only reach it from the ESXi console. 9800-CL1 can ping itself at 10.43.8.20 but not its gateway (10.43.8.1). I can ping, ssh, https to my other 9800-CL2 (10.43.8.21) from my pc (10.59.9.15) fine because its g1 interface is layer 3. both of my 9800-CL VMs run iosxe17.6.4.
===9800-CL1 config===
interface GigabitEthernet1
  switchport trunk allowed vlan 3
  switchport mode trunk
  negotiation auto
  no mop enabled
  no mop sysid
interface GigabitEthernet2
  negotiation auto
  no mop enabled
  no mop sysid
interface GigabitEthernet3
  negotiation auto
  no mop enabled
  no mop sysid
interface Vlan1
  no ip address
  shutdown
  no mop enabled
  no mop sysid
interface Vlan53
  description wmi
  ip address 10.43.8.20 255.255.254.0
  no mop enabled
  no mop sysid
ip route 0.0.0.0 0.0.0.0 10.43.8.1
===9800-CL2 config===
 description wmi, rmi
 no switchport
 negotiation auto
 no mop enabled
 no mop sysid
 negotiation auto
 no mop enabled
 no mop sysid
interface Vlan1
 no ip address
 shutdown
 no mop enabled
 no mop sysid
ip route 0.0.0.0 0.0.0.0 GigabitEthernet1 10.243.8.1
!i tried this default route on 9800-CL1 and got this error: %Must specify a L3 port as the next hop interface
Hi @k. cheng
  The default route seems not right.
It should be
ip route  0.0.0.0  0.0.0.0  10.243.8.1
k. cheng
sorry, that was a typo. to clarify, the default route on the reachable wlc is ip route 0.0.0.0 0.0.0.0 GigabitEthernet1 10.43.8.1 and the default route on the not-reachable wlc is
ip route  0.0.0.0  0.0.0.0  10.43.8.1. for the reachable wlc, the iosxe added GigabitEthernet1. i tried adding GigabitEthernet1 to the default route of the not-reachable wlc and got an '%Must specify a L3 port as the next hop interface' error.
JPavonM
Regarding the importance of configuring WMI as SVI, one of the answers would be that using SVI is the only way you can use an AP in sniffer mode to capture OTAs. Maybe other things are also supported using SVI that are not using physical port in L3 mode that I can't remember now.
Regarding your WMI connectivity issue, this use to happen if the port group configuration in the Hypervisor side has not the proper config.
Check this https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-cl-wireless-controller-cloud/nb-06-cat9800-cl-wirel-cloud-dep-guide-cte-en.html#vCenter
marce1000
  - You may want to review the 9899-cl controller configuration too with the CLI command show tech wireless ; feed the output into : https://cway.cisco.com/wireless-config-analyzer/
  Consider this a 'must do'....
 M.
