01-05-2021 04:13 AM - edited 07-05-2021 12:58 PM
Hello everyone,
to use EWC on Cisco Catalyst 9000 switch family,
do I have to license both the switch and the access point with DNA subscriptions?
01-05-2021 04:19 AM - edited 01-05-2021 04:44 AM
That will depend on the firmware of the switch.
If I remembered correctly, 17.2.1 (and earlier) require DNAC (appliance) SD-Access to manage the embedded WLC.
Starting with 17.3.1, DNAC (appliance) SD-Access is no longer required to manage and configure the embedded WLC.
01-05-2021 04:30 AM
Thanks @Leo Laohoo
I have inserted an attachment in which I have highlighted the release and licensing required.
do you confirm this highlighted?
01-05-2021 04:45 AM
01-05-2021 04:49 AM
Read the Release Notes carefully.
Nowhere do I see anything mentioned about not being able to work with Essentials license.
01-05-2021 04:56 AM
if essential licenses are also good, should they be taken both on the switch and on the AP?
01-05-2021 02:34 PM
No, only the switch.
01-05-2021 04:50 AM
is this OTT deployment or part of SD-Access ?
01-07-2021 03:08 AM
@balaji.bandi it is no-SD Access.
it is a three level university campus:
Access, distribution and Core.
The idea is to use Embedded wireless on Catalyst 9K switches rather than the 9800 wireless controller.
So my doubt is to understand if you need to activate the DNA licenses as well as the switches also the access points.
01-07-2021 05:10 AM
CAt 9K support inbuild WLC feature, make sure you have right License to use that feature.
