9800 WLC - CLI command for AP Primary controller assignment?
brettlarkins
Level 3
Level 3
Been working more and more with the 9800 WLC's recently and starting to get more comfortable with them...
Does anyone know what the equivalent CLI command is in the 9800 WLC for "config ap primary-base WLC03 Cisco_AP_1 192.168.142.12"  That was used in the Aireos WLC to assign a primary and secondary WLC to AP's?
Rasika Nayanajith
Here it is
c9800#ap name <AP_NAME> controller ?
primary Configure primary controller
secondary Configure secondary controller
tertiary Configure tertiary controller
c9800#ap name <AP_NAME> controller primary WLC1 ?
A.B.C.D Primary Controller IPv4 address
X:X:X:X::X Primary Controller IPv6 address
<cr> <cr>
Rasika
*** Pls rate all useful responses ***
11 Replies 11
Rasika Nayanajith
Here it is
<cr> <cr>
Rasika
Worked perfectly... Thank you, Rasika!
Hi @brettlarkins @Rasika Nayanajith,
Would you expect this also to work if let's say I have a 5508 and 9800 WLC, then I want to revert back to the old controller (5508) joining for this specific AP? I asked this because, I have this setup where I want to test it out using those commands and send it to the AP. First migrate the APs from old controller to the new controller and then what if I want to revert back to the old controller, would I expect this just fine? I'm using static IP addressing for the APs.
Thanks it worked very well
It Is there a way to do it massively by GUI or CLI? in the 9800 wlc
You have to get AP names and workout CLI command script in .txt file and then apply it in one go.
Rasika
Hi, is there a CLI command to remove the secondary controller name and IP ?
thanks!
You can use below CLI command to remove secondary configs
9800-WLC#ap name <AP_NAME> no controller secondary <WLC_NAME> <WLC_MGT_IP>
Rasika
Bruno Dinis
Level 4
Level 4
Guys, thanks for the help
is there any command to know the current Primary and Secondary Controllers?
I want a show command and not a config command.
Thanks!
            >....is there any command to know the current Primary and Secondary Controllers?
                               9800# show ap name <APname> config general
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Since this is AP specific configuration, you have to issue it for each AP name individually (as Marce1000 responded). However if you have many APs on WLC, you can get filtered output using below.
WLC2#sh ap config general | in AP Name|Primary|Secondary
Cisco AP Name : AP5-C9166
Primary Cisco Controller Name : WLC2
Primary Cisco Controller IP Address : 192.168.130.20
Secondary Cisco Controller Name : WLC1
Secondary Cisco Controller IP Address : 192.168.130.10
Rasika
