9800 wlc how to turn off the wireless signal of a specified AP
id404
As the AP deployment is relatively dense, some of the wireless signal overlap serious, intends to turn off the wireless RF signal of one or two of the AP, please ask how to operate?
Rasika Nayanajith
If you like to do it via GUI, you can easily navigate "Configuration -> Wireless -> Access Points -> "select AP under 5GHz or 2.4GHz radis" -> Disable admin status"
Rasika
*** Pls rate all useful responses ***
7 Replies 7
Leo Laohoo
In enable mode:
ap name <AP_NAME> shutdown
 If you want to disable a specific radio on the AP but not the whole AP, use this:
ap name YOUR_AP_NAME dot11 24ghz shutdown
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_wl_16_10_cg/802-11-parameters-for-cisco-access-points.html
Rasika Nayanajith
Rasika
Hi Rasika. Do you know if we can do this via CLI?
There are many ways to do this:
1.  Admin disable the AP
2.  Turn off the radios individually
3.  Put the AP in an Policy Tag with zero SSID
All can be done using CLI or GUI.
 - @Tony M   FYIhttps://community.cisco.com/t5/wireless/9800-wlc-how-to-turn-off-the-wireless-signal-of-a-specified-ap/m-p/4628744/highlight/true#M243081
  M.
Thanks. I saw this before but tried from configuration mode... Worked in exec mode!
