9800 WLC LWA Guest access using Lobby Admin - per SSID?
mqontt
Hey Guys,
i was wondering if there is a way to allow Lobby admin to create a guest user where he would be able to specify that user is allowed to only join specific SSID.
Ie: i have 2 SSIDS (webauth1 and webauth2)
Lobby admin logs into the wlc and creates a guest account. But that guest account is valid on all WLAN profiles (SSIDs). And i would like to know if there is a way to restrict it per wlan profile.
I know this might be doable within the CLI, but for that you'd need admin privilege level (to edit guest user using cli).
thnx
M
marce1000
 - I would presume that this can be accomplished with background NAC schemes too , where the authenticating servers could then restrict the user to particular WLAN (note that anyone can see any SSID and attempt to connect to it)
 M.
mqontt
Yea thats what i thought but unfortunately this customer doesnt have any NAC
 - In that case , the customer may better plan that for the future and or lobby admin must be redirected to IT-staff , e.g.
 M.
