9800 WLC Support for PSU and fan state SNMP OID (1.3.6.1.4.1.9.9.13)
leandropavon
Has anyone had experience with this bug? CSCwa23598
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwa23598
I see that there are many customers who use an SNMP tool to monitor all the IT of their company in a transversal way, and not being able to monitor power supplies and fans of the WIFI controllers seems very serious.
I understand that with DNA Center, telemetry can be used to access this equipment information, but DNA is not a transversal solution to monitor non-Cisco equipment, and in any case there are important clients that have already invested in a standard-based solution SNMP.
Thanks.
Rich R
Your options are limited.  As I've explained in previous posts Cisco is now concentrating on streaming telemetry and SNMP is low priority for them.  That enhancement defect might get fixed in a later release but don't count on it.
Nobody forces you to use DNAC for telemetry.  You can use other products or even your own open-source based solution.
Otherwise you must look at other simple options:
You can still use SNMP traps or syslogs instead of polling the MIB.
If there isn't a specific trap for those (I haven't checked) then you can use an EEM script to generate an SNMP trap from the logs and then your NMS can act on the trap.  Obviously you'll need a custom trap definition for that to match your own generated trap.
Rich R
leandropavon
Thanks a lot @Rich R
Your proposal is a good workaround.
I think I will try this option.
