a/g/n and a/n
csco11030279
why in cisco WLC we find a/g/n and a/n ? I mean why a/g/n togather and a/n togather ? what is the relationship in a/g/n and the relationship in a/n?? byanother words why a/n companed togather in WLC orWCS and the a/g/n also comained togather also why not g/n ??
Scott Fella
Can you post a screen shot. You should only see two, one will be 802.11an and the other 802.11bgn.
-Scott
Bob Bagheri
I believe this way you can seperate your wireless network antenna settings for 5GHz only networks vs. mixed 5 and 2.4 GHz.  For example channel bonding is not something you want on your 2.4 GHz network.
Hope that helps.
Bob
Stephen Rodriguez
Are you looking at the 'radio' selections under the WLAN properties?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
csco11030279
I hope this can describe more my question !!
