06-26-2013 04:08 AM - edited 07-04-2021 12:17 AM
Hi all,
I have a wireless controller with version 7.2 . access point
AIR-LAP1142N-E-K9 is working fine but access point AIR-CAP1602E-E-K9 doen't join the group(it's getting ip address and the see the mac address asw ell.) .Anyone can give me a clue why this is not joining??I am in a critical situation.
Solved! Go to Solution.
06-26-2013 05:01 AM
My first response to your post, I've included a link to a table which gives you the model of APs and the softwares supported.
1602 and 1140 are in that list.
06-26-2013 04:15 AM
AP1602 is supported with WLC firmware 7.4.100.0.
06-26-2013 04:51 AM
thanks a lot for the prompt answer.But if I upgrade this controller to the 7.4,will the remaining a/p-1142 work with 7.4??
thanks
06-26-2013 05:01 AM
06-26-2013 05:18 AM
Thanks a lot Leo.
have great day
