acces point  1131 cisco
Dhikra Marghli
Level 5
Level 5
Hello
i have a acces point Product/Model Number : AIR-LAP1131G-E-K9  with version Version 12.3(8)JEA
and controller wireless virtuel avec ios 8.9.100
so i want to know what is version image ios  in acces point  1131 to work with this image controller virtual 8.9.100
thanks in advance
show version
Cisco IOS Software, C1130 Software (C1130-K9W7-M), Version 12.3(11)JA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 17-Jul-07 19:04 by hqluong
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (fc2)
ap uptime is 3 minutes
System image file is "flash:/c1130-k9w7-mx.123-11.JA4/c1130-k9w7-mx.123-11.JA4"
--More--
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1131G-E-K9 (PowerPCElvis) processor (revision D0) with 24566K/8192K bytes of memory.
Processor board ID FCZ1424Q10M
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 54:75:D0:B8:0D:BA
Part Number : 73-11587-02
PCA Assembly Number : 800-30422-01
PCA Revision Number : B0
PCB Serial Number : FOC14224L86
Top Assembly Part Number : 800-29582-02
Top Assembly Serial Number : FCZ1424Q10M
--More--  Top Revision Number : A0
Configuration register is 0xF
ap#sho
ap#show ip inter
ap#show ip interface br
ap#show ip interface brief
BVI1 192.168.0.22 YES DHCP up up
Dot11Radio0 unassigned YES NVRAM up up
FastEthernet0 unassigned YES NVRAM up up
ap#sho
ap#show run
ap#show running-config
Building configuration...
Current configuration : 1426 bytes
version 12.3
no service pad
service password-encryption
hostname ap
enable secret 5 $1$BUK9$q5q4xhmrA6Y1ZTAsRaacu0
ip subnet-zero
no aaa new-model
dot11 ssid SOTETEL
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 0812435A0C0D001B405B5D5D
--More--  !
dot11 ssid TT-WIFI
authentication open
guest-mode
power inline negotiation prestandard source
username Cisco password 7 14341B180F0B
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid SOTETEL
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
--More--   channel 2422
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
--More--  no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
ap#
ap#
and i send screen shot for acces point
7 Accepted Solutions
marce1000
 - I think this ap-model is no longer compatible with 8.9 google on 'cisco wireless compatibility matrix' to get the compatibility-info's for various ap-models, controllers and software releases.
 M.
Sandeep Choudhary
1131 AP last Supported version is 8.0.X so you should run 8.0.X On wlc to join it.
Hi @Dhikra Marghli
It's no possible, the last version that support models 1130 is 8.0.152.0 and you AP needs 153-3.JA12
15.3(3)JAA12 12.4(25e)JAP12. Please check the wireless compatibility Matrix.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
spero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
*Tu reconocimiento nos alienta a seguir participando en los foros *
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
Leo Laohoo
The final WLC firmware the 1130 is supported on is 8.0.X.X.
There are only two ways to make it work.
1. Either conver 1131 AP to Autonomus AP
2. Or Donwgrade vWLC to 8.0.152.0 version then 1131 will join to vWLC.
Dont forget to rate helpful posts
Here is the link for 1130AG:
https://software.cisco.com/download/home/279537722/type/280775090/release/12.4.25e-JAP12
yes.
Intstall Autonomous image to make it as standalone AP: https://software.cisco.com/download/home/279537722/type/284180979/release/12.4.25d-JA1
or
downgrade vWLC to 8.0.152.0 version
13 Replies 13
marce1000
 M.
Sandeep Choudhary
Hi @Dhikra Marghli
Leo Laohoo
Hello
i can  possiblity convert ios Acces point 1131to other image ios that controller can join this acces point  without  change image ios controller virtual ???
thanks in advance
 Product/Model Number:AIR-LAP1131G-E-K9
 Top Assembly Serial Number:FCZ1424Q10M
 System Software Filename:c1130-k9w7-tar.123-11.JA4
 System Software Version:12.3(11)JA4
 Bootloader Version:12.3(8)JEA
 System Uptime:11 minutes
The AP can be converted to autonomous IOS which means the AP can be configured like an ordinary AP.
I means  Access Point IOS Release for this acces point :
For       TO         ===========>  other  Access Point IOS Release without change IOS relase controller 8.9.100 ??
it is possible or NOT ???????
 Bootloader Version:
12.3(8)JEA
thanks
Sandeep can you send me the  link to download image ios release  from Site Cisco  153-3.JA12   /// 15.3(3)JAA12 /// 12.4(25e)JAP12
May be when i can try for this IOS , the Vcontroller can join this acces point
thanks in advance
Hello
Sanddep you say :
SO the final solution is :===>
1)  conver 1131 AP to Autonomus AP :=========> how i can do that ???, with this IOS  Realse https://software.cisco.com/download/home/279537722/type/284180979/release/12.4.25d-JA1   !!!!
2) Or Donwgrade vWLC to 8.0.152.0 version then 1131 will join to vWLC.
i wait to reply me
thanks in advance
yes.
or
 - Not  ,
 M.
