Access point 3502i not joining the Virtual wireless controller
g_parmar83
i try to install the two 3502i access points to the virtual wireless controller
but unable to join them to controller.
the lightwieght image running on 3502i is
" ap3g1-rcvk9w8-tar.124-23c.JA2.tar "
need help
and getting error
*Jul  4 13:16:39.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.30.100.200 peer_port: 5246
*Jul  4 13:16:39.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul  4 13:16:39.015: %LWAPP-3-CLIENTERRORLOG: Peer certificate verification failed
*Jul  4 13:16:39.015: %CAPWAP-3-ERRORLOG: Certificate verification failed!
*Jul  4 13:16:39.015: DTLS_CLIENT_ERROR: ../capwap/capwap_wtp_dtls.c:348 Certificate verified failed!
*Jul  4 13:16:39.015: %DTLS-4-BAD_CERT: Certificate verification failed. Peer IP: 172.30.100.200
*Jul  4 13:16:39.015: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 172.30.100.200:5246
*Jul  4 13:16:39.015: %DTLS-3-BAD_RECORD: Erroneous record received from 172.30.100.200: Malformed Certificate
*Jul  4 13:16:39.015: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.30.100.200:5246
*Jul  4 13:16:39.015: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
*Jul  4 13:17:44.103: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul  4 13:17:44.166: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jul  4 13:17:44.166: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jul  4 13:17:44.176: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jul  4 13:17:44.185:  status of voice_diag_test from WLC is false
*Jul  4 13:17:44.185: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jul  4 13:17:44.195: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jul  4 13:17:44.204: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jul  4 13:17:44.220: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jul  4 13:17:54.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.30.100.200 peer_port: 5246
*Jul  4 13:17:54.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul  4 13:17:54.015: %LWAPP-3-CLIENTERRORLOG: Peer certificate verification failed
*Jul  4 13:17:54.015: %CAPWAP-3-ERRORLOG: Certificate verification failed!
*Jul  4 13:17:54.015: DTLS_CLIENT_ERROR: ../capwap/capwap_wtp_dtls.c:348 Certificate verified failed!
*Jul  4 13:17:54.015: %DTLS-4-BAD_CERT: Certificate verification failed. Peer IP: 172.30.100.200
*Jul  4 13:17:54.015: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 172.30.100.200:5246
*Jul  4 13:17:54.015: %DTLS-3-BAD_RECORD: Erroneous record received from 172.30.100.200: Malformed Certificate
*Jul  4 13:17:54.015: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.30.100.200:5246
*Jul  4 13:17:54.015: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
the time is set properly on the WLC
thanks in advance
16 Replies 16
mmangat
Please refer to the following cisco doc "Troubleshoot a Lightweight Access Point Not Joining a Wireless LAN Controller "
This may provide a solution to your query.
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml
tvaughn571
the time is set properly on the WLC did not fix it
