Access point compatibility with Cisco WLC 5520
abinaya.2.r
I have 5520 WLC running on 8.5 version. I need to add few C9120AXE series APs to it for which i will upgrade the WLC for 8.10.
Also i need to add C9124AXI-ROW model APs as the country is china.
My question is weather this WLC model 5520 with version 8.10 will support  C9124AXI-ROW model AP? I know as per the compatibility matrix, 9k series AP will be supported with 8.10 version, but  am concerned about the regulatory domain.
marce1000
  - I can't see support for C9124AXI(-ROW) in https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html  , check Table 7 ,
 M.
Dustin Anderson
It is looking like the 5520 can not run it. Here is the snipit from the product page.
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/nb-06-cat9124-ser-ap-ds-cte-en.html
Software
Catalyst 9124AXI, 9124AXD
●  Cisco IOS XE Software Release 17.5.1/17.3.4 (B Domain) or later
●  Cisco IOS XE Software Release 17.6.2 or later (For all Regulatory Domains)
Catalyst C9124AXE
Catalyst C9124AXI/C9124AXD Embedded wireless Controller
Supported WLAN controllers
●  Cisco Catalyst 9800 Series Wireless Controllers
Leo Laohoo
9124 is only supported in the 9800.
Regardless of the account size, there is no desire to support 9124 in AireOS.
