Access point connection
Richcarr
Community Member
I was wondering if there was a way to see the last known connection for an access point. When an access point is connected, The dashboard will show you where the access point is connected (Switch name, IP address and port number on the switch). After a period of the access point disconnecting, this information disappears. Is there a way to stop this from disappearing?
KH6
Hey @Richcarr
It is stored up to a month, if its been past a month you won't be able to see it anymore, filtering by the last month on your switches, or the last month on the connectivity graph on the AP, or the last month on your clients page with the LLDP filter, should all be ways to see what was connected previously.
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
