Access Point naming system
Maurice Ball
Level 6
Level 6
Could someone please explain to me how the new access point software naming convention works?
c1140-rcvk9w8-tar.152-2.JB.tar
I am trying to determine which WLC version support the above software.
3 Accepted Solutions
Stephen Rodriguez
that image is the 'recovery' image, rcv.
So long as you load the recovery image to the AP, or order the AIR-CAP etc it doesn't matter what image you have.
When the AP joins the WLC, it will do a check to see what version it has versus what the controller is holding. IF there is a mismatch, the AP will download it's new image from the WLC.
Same thing when you upgrade, you only have to upgrade the WLC and the APs will pull their image from the WLC so it has the correct image.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Scott Fella
Any software that has rcv is supported on the WLC. v15 I believe is for v7.4, but I think not will work for any. The AP will eventually get the code from the WLC.
-Scott
Richard Atkin
Level 10
Level 10
Hi Maurice,
Most Wireless interoperability problems stem from the hardware as opposed to the software (as the software is much easier to change than the hardware!).  You might do well to keep a copy of this Cisco Wireless Compatibility Matrix in your browser shortcuts...
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Richard
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Scott Fella
-Scott
Richard Atkin
Level 10
Level 10
Hi Maurice,
Richard
