access point range
suthomas1
Level 7
Level 7
What is the distance range that Cisco Access points can cover in metres,km or feet.
eg. how much distance does cisco 1524 AP or a Work group bridge cover?
Where can we find the figures associated with each cisco access point model.
Thanks in advance!
Scott Fella
You can find one for the 15xx here, but none for APs I'm general. You need to have a site survey done to really see you coverage.
https://www.google.com/url?sa=t&source=web&cd=2&ved=0CDYQFjAB&url=http%3A%2F%2Fwww.cisco.com%2Fen%2FUS%2Fdocs%2Fwireless%2Faccess_point%2F1550%2Frange%2Fcalculator%2F1552_Link_Calculator_V1.xls&ei=yAq2UJaBI8XRyQHBlIDACw&usg=AFQjCNHBZEvU5H-As7WSjl3gEY...
-Scott
Scott Fella
By the way... The excel file is an estimated but I wouldn't use that number because there is a lot of factors that can vary the coverage. One is the client devices.
-Scott
