NCS PI 1.2 Not showing Cleair Sensor as up?
raun.williams
Level 3
Level 3
In troubleshooting some issues, I noticed that on monitoring a few 3602's, the CleanAir Sensor Status would report Down on some AP's, despite on the same controllers and floor, some would report up.  This seems to be only on the g radios as well.   I can tell you for an AP in SE-CONNECT mode, even though it says it's Down, Spectrum Expert has no problem connecting to it and utilizing the G radio.
0 Replies 0
