access point with no Mac address!!!
CSCO11177557
one of access points has become faulty.
It is air-lap113ag-e-k9
The system does not have MAC address yet
The following commands will set MAC address,
parameters used by TFTP operation, and finish
loading the operating system software:
    set MAC_ADDR
    set_param
    ether_init
    tftp_init
    boot
Tried to do set MAC_ADDR, with no luck.
How will i be able to recover this one.
6 Replies 6
Scott Fella
The ap should have a MAC address unless it is faulty. You shouldn't have to enter that info. Is the issue that the ap is booting into ROMMON mode? Do you see an error when you boot up the AP. What does the dir show and also the set?
-Scott
HI Scott;
Thanks for you support.
This is the first thing i see
Xmodem file system is available.
flashfs[0]: 48 files, 14 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 12607488
flashfs[0]: Bytes available: 3391488
flashfs[0]: flashfs fsck took 39 seconds.
Invalid parameter block -- no mac address available.
Unable to figure out local mac address.
    set MAC_ADDR
    set_param
    ether_init
    tftp_init
    boot
ap: dir
List of filesystems currently registered:
               flash[0]: (read-write)
              xmodem[1]: (read-only)
                null[2]: (read-write)
ap: set?
Unknown cmd: set?
ap: set ?
ap:
Nabil
That doesn't look good. You might just have to RMA that AP.
-Scott
That is what i though as well. just done its days, and gone dead:-(
Rgds
Nabil
Yeah... at least it lived for a while:)
-Scott
ooh yahh
looking on the bright side:-)
Nabil
