Access-Point
Hiko
Level 3
Level 3
Access Point AIR-SAP1602I-E-K9 Acess point connect to Wirelless Controller and add to AP groups and i save configuration everthing is ok but when I lan cable plug out from AP after again turn on All configuration deleted . for example  hostname deleted does not join to Ap groups what is the reason? How can i solve this prolem?
16 Replies 16
only one AP happening this problem
Hi Hiko,
Seem like your issue is related to Field Notice: FN - 70330:
Problem Description
Some Cisco IOS® Access Points (APs) report no flash access or file system corruption after an AP reboot. This is most commonly seen when a Wireless LAN Controller (WLC) is upgraded.
The corruption can cause these conditions on the AP:
  • The AP is unable to save the configuration.
  • The AP is unable to perform an upgrade.
  • The AP loses configuration.
  • The AP is stuck in a booting loop.
  • The AP is in bootloader status.
Workaround/Solution
Solution
Caution: Before an upgrade, run the Wireless LAN (WLAN) Poller tool in order to identify affected Cisco IOS APs on the network and fix them.
Refer to the document Understanding Various AP-IOS Flash Corruption Issues in order to understand how to recover APs with flash issues and for details about how to install and run the WLAN Poller tool.
Upgrade the WLC to AireOS Release 8.5.140.0 or Release 8.3MR4Esc (Release 8.3.143.7 or later) in order to obtain the fixes for the issues listed in the Defect Information section. In order to obtain the Release 8.3MR4Esc image, contact the Technical Assistance Center (TAC).
Notes:
  • If you upgrade to a fixed version before you run the WLAN Poller tool, there is a risk that your Cisco IOS APs will be stranded during the upgrade.
  • If the WLAN Poller tool needs to recover affected APs, it will cause those APs to reload once the image is downloaded and installed. Ensure that you run the WLAN Poller tool in a maintenance window.
  • If it is not possible to upgrade the WLC to a fixed code version at this time, and you see that a significant number of APs enter into this state, you should run the WLAN Poller tool every 30 days or more frequently until you can upgrade.
How To Identify Affected Products
These are the only Cisco IOS AP models affected: 1600, 1700, 2600, 2700, 3600, and 3700 Series APs.
<<< Please help the community by marking useful posts helpful, or accept as a solution if it resolved your issue >>>
