Access points / antennas for extreme cold
juantovarm
I have a project where I need to install an AP inside a freezer that goes down to -40°C. I was looking into the Aironets 1560, but that temperature is borderline. I've also thought about just placing an antenna in the freezer and the AP outside, but antennas such as the AIR-ANT2547VG-N also have that temperature limitation.
The idea is try to stay within Cisco Mobility Express because there are 2 other 1560's already in place
Has anyone used any of these under such conditions?
Any other possible solutions?
Scott Fella
You just need to find an ap that supports the temp limits of the freezer. It’s the same for any antenna you might find. I think you are safer with the ap as long as the specs says so.
-Scott
Scott Fella
-Scott
