Wireless Controller and AP config
eherlex
Visitor
Hi.
I'm new to the this type of work and i need help.
I have to configure a Cisco 5508 WLC and a Cisco ap air-lap1142n e k9 access point, and i can't find any usable information about how to do it.
I have difficulties to understand how to connect the wlc and the ap, how to config the ap properly. And a reassuring would be nice about the proper wiring of the config. (WLC service port to my pc, console cable (with usb adapter) to my pc, AP to power injector, power injector to a TP-Link switch, switch to wlc gigabit port1)
Thank you for any help you can give.
6 Replies 6
Mark Elsen
 - Basically the ap only needs to find the controller, usually done with using DHCP option 43 on the dhcp server, controller-based AP's get all their configuration information from the controller afterwards. More fundamentally , you are using very old equipment, both controller and ap. There may be compatibility and code difficulties , concerning expired certificates on the AP. Before doing all the work, consider using a modern controller + ap.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
It is a University task, so i can't change my equipment, and i dont have access to newer ones but it is worked before, so it should work now i guess. Thank you for your help by the way, i will try it.
Scott Fella
There are so many documents, blogs and videos on the basics. Just review a few of them to get a better understanding, you will have to do that in order to understand how this works and functions.
https://www.networkstraining.com/cisco-wireless-lan-controller-configuration/ <>
-Scott
Add further to @Mark Elsen's comments - because you're using such very old hardware you're almost guaranteed to run into problems with expired certificates so you'll need to read https://community.cisco.com/t5/wireless-mobility-documents/lightweight-ap-fail-to-create-capwap-lwapp-connection-due-to/ta-p/3155111 and the field notice it refers to.  You'll need to make sure you're running a version of code with the workaround/fix and configure the workaround.  If the MICs have already expired you'll have to disable NTP and set date to before the cert expiry dates to get it working before you can even configure the workaround.  You should highlight to your employer that this hardware is end of life and may be subject to multiple security vulnerabilties (in other words it is a security risk to the organisation and users) but hackers will love you for making their life easy to steal user data 🙂
https://www.cisco.com/c/en/us/obsolete/wireless/cisco-aironet-1140-series.html
End-of-Support Date: 2018-09-30
https://www.cisco.com/c/en/us/products/collateral/wireless/5500-series-wireless-controllers/eos-eol-notice-c51-740221.html
End of Vulnerability/Security Support HW: The last date that Cisco Engineering may release a planned maintenance release or scheduled software remedy for a security vulnerability issue. July 31, 2021
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Thanks for your comment. It's a university task, i don't have a choice of equipment, i need to work with what i've got, so the hackers will be the sys admin's concern. This exact ap and wlc worked together before. They reset them and gave them to me. So if the clocks are after the end of support date, the wlc and the ap just refuse to work? Neither of them are connected to the internet.
So if the clocks are after the end of support date, the wlc and the ap just refuse to work? NO (not with these anyway)!
End of support means no updated software, documentation, bug fixes, security fixes and no support for modern WiFi standards.
So if the clocks are after the certificate expiry dates the wlc and the ap just refuse to work - unless you implement the workarounds for that which is a combination of software update, config and changing the date/time - all done in the right order.  Certain combinations of hardware and software will only continue to work by keeping the clock at a pre-cert expiry date because the fix didn't apply to them because they were already out of software maintenance support at the time of the fix.
