Access Points are not running on same SSID
takyon.networks
I have 8 no. AIR-LAP1131AG-A-K9 and WLC 2112 Wireless LAN Controller,i configured the device and its working at deffent SSIDs but when i am trying to enable same SSID on all LAP it shows "AP on dupplicate SSID found and Layer 2 security found".
nikhilcherian
Level 5
Level 5
Can you please be more elaborate on what do mean by enabling ssid on each AP. If the WLAN number is less than 16 and if the ap are in the default ap-group the WLAN will be enabled on the AP
Are you using some 4.X builds
