ACS 4.0 Authen-Failure-Code
lunestadr
I'm getting this Authen-Failure-Code in Failed attempts report when I try to authenticate with PEAP against a ACS 4.0:
"Authetication session invalidated"
I'm not able to find ny reference to what this means ? has anyone any info on this and what it points to as a problem?
best regards rolf
aghaznavi
Level 10
Level 10
Are you trying to authenticate Windows xp clients using PEAP,If so i dont think so it will workout, you have to use Cisco's aironet client utility for PEAP against ACS.
