ACS Authentication WiFi Users
thomas19991
Community Member
Hi, I can configure wireless client authentication using the user local database in the ACS, whitout use LEAP Authentication? (The devices of this wifi solution, are WLC 2106 and ACS 4.2).
dancampb
Level 11
Level 11
Sure, you could create the user account locally on ACS and use EAP-FAST or PEAP as your authentication method.
Thanks.
To configure the solution, I need to complete this Steps?:
1. Add users  in the ACS (User Setup section)
2. System Configuration / Global Authenticacion Setup / Enable the EAP Configuration in the ACS.
There is someone guide with example ¿?
I understand the configuration of the WLAN , my doubt is about the configuration o precedure to configure the ACS.
