07-13-2013 01:57 PM - edited 07-04-2021 12:24 AM
hello
which hardware appliance model and version is advisable for ACS to be integrating with WLC. The appliance should support 1200 users and should integrate with Microsoft Active Directory 2008.
cheers
Paul
07-13-2013 03:59 PM
You would want to use ACS v5.4 which is the latest. Here is the appliance specifications.
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps5698/ps6767/ps9911/data_sheet_c78-715717.html
07-13-2013 11:47 PM
You can also use Cisco ISE instead of Cisco ACS. In a couple of years ISE will replace ACS.
Please rate if this helps
07-14-2013 05:28 AM
ISE is much more expensive and if your just wanting to do radius, even using a Microsoft radius can be used. ISE does have more features if you need more than just radius features too. ISE hopefully will replace ACS, but when. It will first need to really and truly support tacacs first. That is one big reasons people still need ACS is for tacacs.
