07-13-2013 10:09 AM - edited 07-04-2021 12:24 AM
Hello, WiFI experts!!!
I have been tasked to do a wireless installation for a very harsh factory environment with huge metal bins and crane moving laterally.
Is it possible to have an access point, pointing downwards, attached to the crane?
The point of having this AP on a moving crane is... when this crane passes by the wall mounted AP's, the signal will be disrupted/blocked by the crane itself. so, to ensure wireless connectivity, I was thinking of placing an AP under the crane so wherever it blocks the signal, there will still be coverage.
Please see the following link on how the crane moves and looks like.
http://www.youtube.com/watch?v=-0HqEyBIKoM
Is this possible with the 1552 AP?
thanks!
07-13-2013 10:45 AM
That is tough... What you have to look at is your solution seems to be an answer, but what happens when clients that are connected to the AP and then the signal gets blocked. Client devices should roam but that is up to the client. Why not test that with a regular access point and not a mesh AP.
07-13-2013 08:24 PM
You can put an AP pointing downwards, attached to the crane but I don't think that it will resolve your problem. When client moves form one AP to others proper hand off must be done in your scenario it is not possible we have to search another way around. Really very tuff scenario.
07-14-2013 09:26 AM
one stable side local mode and the moving side wgb mode will be a good choice
