Adding an additional SSID to WLAN
Rudy Lallemand
Frequent Visitor
Frequent Visitor
We have a CISCO WLAN in place with several SSIDs including one on the Voice VLAN. We need to add an additional one using CCKM due to wireless phone roaming issues. Does adding a new SSID to the WLAN cause any outage whatsoever?   We are in an environment where even a small amount down time is not acceptable.
We are using two 5500 controllers with hundreds of LAP1142N
Thank you
Damon Garner
No, adding a wlan to the controller will not cause any downtime.
Hi Rudy,
How many WLANs do you have? You should be aware anything more than 5 or so could be problematic if your wireless isn't deigned correctly.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
