Indoor vs Outdoor FCC rated APs
thefranmanatt
So  I am being told 1 or 2 years ago the FCC changed the way APs are  certified.  That the manufactures certs the APs for either indoor or  outdoor.  Can anyone confirm this?
Does this mean an indoor AP  can NOT be used outdoors?  Or does it mean a professional has to install  it to meet the FCC outdoor rules (power and channels)?
thanks
CCNP - Wireless
CWNE #136
5 Replies 5
George Stefanick
It pretty simple. You just need to make sure you do not exceed the FCC reg for outdoor. And keep in mind that UNII2 ,UNII2E has different power standards than UNII3.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
I am guessing the samething but have you every heard of the indoor/outdoor FCC rating before?
Yes. These ratings are to allow indoor use of 5 ghz and outdoor use. The outdoor rating allows for more power.
Going off memory
Unii 3 is 1000 mw while 80211 states 800mw
Going off memory
Oh boy, George.  I think you need to spend more time with your "Betsy".
Welcome back Leo!
