Adding Antenna in WCS for coverage prediction
Can I add a custome based antenna in WCS for coverage prediction?
Scott Fella
What do you mean? The antennas you can choose are only Cisco branded antennas. If they are different manufacture, it will not be in the list. You can try to choose something similar and also set the dbi for the antenna.
http://www.cisco.com/en/US/docs/wireless/wcs/7.0/configuration/guide/7_0maps.html#wp1126390
http://www.cisco.com/en/US/docs/wireless/wcs/7.0/configuration/guide/7_0apcfg.html#wp1095547
-Scott
Abhishek Abhishek
Depending on the version of your WCS ...
Go to Configure > Access Point > choose the AP of your choice > under Radio Interface choose 802.11a/n > under Antenna is External Antenna drop down box.
aqjaved
Level 3
Level 3
WCS provides the ability to enable or disable the use of specific  antennas. All antennas are enabled by  default. At least one transmitting and one receiving antenna must be   enabled. You cannot disable all transmitting or all receiving antennas at once.
Pease check the below links which may be helpful for you:
Link-1
http://www.cisco.com/en/US/docs/wireless/wcs/7.0/configuration/guide/7_0apcfg.html#wp1095504
