Adding Wireless APs (1262s) to 5508
Colin Higgins
Level 2
Level 2
I am putting in a new 5508 controller. I've built the WLANs, activated the wireless, and configured the network for DHCP.
When I add a new 1262 wireless AP to the network, it gets an address from DHCP, but then says it cannot communicate with the controller (it is on the correct vlan/subnet--the same as the controller).
Not sure what I am missing here, and the errors are not telling me much
any advice would be great
blakekrone
Level 4
Level 4
Along with the time that Scott mentioned what version of code are you running? The 1262's require either 7.0.98 or 7.0.116 depending on the model.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp41742
5 Replies 5
Scott Fella
Make sure the time is set correctly on the wlc.
Scott Fella
Sent from my iPhone
-Scott
The time is correct on the controller
Post the output from the AP when consoled in.
Scott Fella
Sent from my iPhone
-Scott
blakekrone
Level 4
Level 4
It needed a code update to 7.0.98
thanks!
