Clients through AP error authenticating to NPS RADIUS
ayussuf
See below config. All IP Addresses are correct and I have other AP which works. However, this one does not. They are using the same RADIUS settings.
On the client machine I am getting a EAP/TTLS box asking for Domain/Username and Password (Token). If I add my username and passord. it still does not authenticate.
The client settigns is correct too since the same computer can connect to oother AP using the User credentials.
version 12.4
no service pad
service password-encryption
hostname FRD-WAP01-1
aaa new-model
aaa group server radius rad_eap
server 172.16.0.43 auth-port 1645 acct-port 1646
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
clock timezone -0500 -5
clock summer-time -0400 recurring
ip domain name aa.corp
ip name-server 172.16.1.53
ip name-server 172.16.1.50
ip dhcp-server 172.16.1.50
ip dhcp-server 172.16.1.53
dot11 ssid Test
   authentication open eap eap_methods
   authentication network-eap eap_methods
   authentication key-management wpa version 2
   guest-mode
power inline negotiation prestandard source
username Cisco password 7 01300F175804
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid Test
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid Test
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 172.16.0.81 255.255.0.0
ip helper-address 172.16.1.50
ip helper-address 172.16.1.53
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 172.16.0.43 auth-port 1645 acct-port 1646 key 7 ****************
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
sntp server 172.16.1.50
sntp broadcast client
end
Stephen Rodriguez
The config looks ok. You don't need the network EAP as you aren't doing LEAP, but that shouldn't hurt you here.
If the client is getting prompted for credentials it sounds like the AAA and client aren't negotiating the eap type properly. Can you look at the NPS logs when the client is failing and see what the error is?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Below if the event from the NPS Server. Instead of "guest" it normally says the user login name.
Log Name:      Security
Source:        Microsoft-Windows-Security-Auditing
Date:          1/19/2012 11:51:45 AM
Event ID:      6273
Task Category: Network Policy Server
Level:         Information
Keywords:      Audit Failure
User:          N/A
Computer:      PLN-NPS.aa.corp
Description:
Network Policy Server denied access to a user.
Contact the Network Policy Server administrator for more information.
User:
Security ID:                              AA\Guest
Account Name:
Account Domain:                              AA
Fully Qualified Account Name:          AA\Guest
Client Machine:
Security ID:                              NULL SID
Account Name:                              -
Fully Qualified Account Name:          -
OS-Version:                              -
Called Station Identifier:                    7081.0545.4bd0
Calling Station Identifier:                    0022.5f5f.31e1
NAS:
NAS IPv4 Address:                    172.16.0.81
NAS IPv6 Address:                    -
NAS Identifier:                              FRD-WAP01-1
NAS Port-Type:                              Wireless - IEEE 802.11
NAS Port:                              363
RADIUS Client:
Client Friendly Name:                    FRD-WAP01-1
Client IP Address:                              172.16.0.81
Authentication Details:
Connection Request Policy Name:          AA Secure Wireless Connections
Network Policy Name:                    -
Authentication Provider:                    Windows
Authentication Server:                    PLN-NPS.aa.corp
Authentication Type:                    EAP
EAP Type:                              -
Account Session Identifier:                    -
Logging Results:                              Accounting information was written to the local log file.
Reason Code:                              34
Reason:                                        The user or computer account that is specified in the RADIUS Access-Request message is disabled.
Event Xml:
http://schemas.microsoft.com/win/2004/08/events/event">
    6273
    0x8010000000000000
    342030
    Security
    PLN-NPS.aa.corp
    S-1-5-21-3370326106-2379687522-1592785168-501
    AA
    AA\Guest
    S-1-0-0
    7081.0545.4bd0
    0022.5f5f.31e1
    172.16.0.81
    FRD-WAP01-1
    363
    FRD-WAP01-1
    172.16.0.81
    Aa Secure Wireless Connections
    Windows
    PLN-NPS.aa.corp
    EAP
    34
