Additional Options for WLC 9800 Upgrade
Electronic20
Hi Comunity , For the upgrade, I get these options:
which is recommended to enable "AP Image Predownload" or "Enable Hitless Upgrade" or both options?
Regarding install APSP, which "AP Upgrade per Iteration" option is recommended? 5%, 15%, 25% or One-shot? as shown in the image below:
Please your kind support with my queries.
2 Accepted Solutions
JPavonM
You can backup the C9800-CL in two ways, 1.) take a snapshot of the C9800 OVA, or 2.) backup your current config with 'show running-config' and restore it on a new OVA in case you re-deploy it.
7 Replies 7
Leo Laohoo
Please read THIS.
Hi @Leo Laohoo
As an additional detail, the WLC 9800-CL is virtualized in a visualization server.
Is the virtualized WLC upgrade procedure the same as a physical WLC?
In the virtualized WLC, what precautions should I take when upgrading?
I have never used the VM version.  So I cannot guarantee the One-Hit-Wonder is applicable (or not).
JPavonM
@Electronic20 yes all procedures and precautions are the same for virtualized WLCs.
If not been told before, I would recommend you to backup the current configuration before upgrading. I suffered an issue when upgrading where the WLC lost almost all static configurations for APs, but I was unable to reproduce it so TAC wasn't able to analyse it.
Thank you @JPavonM ,
In the case of the WLC 9800-CL displayed, would your configuration backup be in an .ova image?
JPavonM
thank you @JPavonM
