adminstrative login WIMS/Controller via ACS
g.rienstra
Level 3
Level 3
? want to use ACS to verify the (management) login to the WISMs. Does anyone know if this is possible. I can only find related ducumentation about WISM/ACS for wireless clients and not for the management loginin to the console/telnet/explorer
Goen
b.hsu
Level 11
Level 11
Yes. It should be possible to authenticate management users of WISM through ACS server. I have done it with WLC's. There is a document in cisco for controllers.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080782507.shtml
Richard Atkin
Level 10
Level 10
Add your ACS server as a RADIUS client.
Set that server to be used for Management logins.
On the ACS server, configure your group with suitable RADIUS permissions.
Job's a good'un
