AES-CCMP and 1300 bridges
david
I'm looking for a document showing the settings and how to use AES-CCMP with the latest firmware on the 1300 bridges.
smahbub
Level 6
Level 6
Is this support rolled out yet? I do not think AES is supported on these platforms yet.
I use my Br1300 in bridge-mode with WPA-PSK and aes-ccm. Note the bug mentioned in the config.
*** root***
interface Dot11Radio0
no ip address
no ip route-cache
no concat (CSCef66724)
cca 61
station-role root
encryption mode ciphers aes-ccm
ssid xxxx
authentication open
authentication key-management wpa
infrastructure-ssid
wpa-psk ascii 0 1234567890
***non-root***
no ip address
no ip route-cache
cca 61
station-role non-root
ssid xxxx
authentication open
infrastructure-ssid
