After Flex connect configuration External guest SSID is not working.
siddhukaturi1
Hi Team,
We have a medium level company, recently we enabled Flex connect and connected some of the users from remote locations. Now the problem is after enable Flex connect in WLC 5508 we are unable to join the network AR- external Guest and this not not part of our local network, this SSId we are using for guest users to access internet.
TOtal SSID's :
Amararaja                                      - > Local users in same building
Amararaja-internal-guest               - >users of amararaja in other locations, whenever they came to local office they will connect this to access all        servers.
Amararaja - external- guest              - >users for outside to access internet.
Flex conncet we enable for Amararaja and Amararaja-internal-guest  and those tow are working fine locally and remotely.
But for Amararaja - external- guest  is not working locally. it is showing no internet connection.
After enabling flex connect we are getting the problem, some one kindly help us on this issue.
Thanks in advance.
0 Replies 0
