AIR-ANT2566P4W-R= Ceiling Mount
Catiare
I have some AIR-ANT2566P4W-R= that I will use for deployment between racks in a warehouse. Wall-mount is not practical due to positioning and distance of said racks. Can these be installed in the ceiling?
p.lan
Yes, absolutely. When you say 'in the ceiling', but it's a warehouse, I presume you'll mount it onto some beams or truss'. But yes, I have mounted these onto the ceiling in warehouses plenty before and it works great. The P4W creates a really nice throw onto the floor for warehouse aisles.
depends on angle required. if directly pointing down easy with just something to mount off.
if need angle look at https://ventevinfra.com/ or https://oberonwireless.com/
they have some nice mounts for these antennas, some also mount the ap with the antenna
*****Help out other by using the rating system and marking answered questions as "Answered"*****
