AIR-ANT2566P4W-R orientation
aleopoldie
Level 3
Level 3
Hello experts, I have a doubt concerning the orientation of the antenna 2566P4W-R. When you look at the azimuth for example (regarding to the patterns in attachement), do I have to consider the antenna horizontally or vertically ? I see the difference for an omnidirectional antenna, but I'm having doubts for directionals. Thank you,
6 Replies 6
Scott Fella
An omni antenna is always placed horizontal and a patchy id positioned vertical when looking at the azimuth and elevation.
-Scott
Hello Scott,
I mean, there is a difference between azimuth and elevation, so for a directional antenna, should it be something like :
Azimuth:
Elevation:
Or the contrary ?
It's the other way around.
The way I remember is "elevation" sounds like an "elevator" which goes up and down (unless you're thinking about the elevators in the Luxor).
The other way around ? Are you sure ?
If we consider azimuth as horizontal, what I put on my previous post was correct, wasn't it ?
Both are considered vertically positioned. Horizontal is when the patch is laying down eithe on the back or front.
Antennas should always have the cabling downward especially if mounted outside.
-Scott
Leo Laohoo
The antenna needs to mounted against a flat wall surface.  So which one is the front & the back?  There should be a yellow sticker to state which is the front and the back.
Next, see the wire?  Wire should be pointing to the ground.  This is very important to ensure prevent water ingress.
