02-27-2012 03:20 PM - edited 07-03-2021 09:40 PM
weak signal, I donno how to imrove it is there any suggestion ???? pleaseeeeeeeeeeee
02-27-2012 03:33 PM
02-28-2012 09:15 AM
That one for 1242AG not 1242G;;;; (((, my AP is 1242G , I increased the gain , I used as dummy suggestion 5GHs antenna, I have changed also the power transmition , relocation , I turnd off all AP arround this AP to remove any kind of interference , I forced the AP to use channel 1,3, and 11 , also to use channel 10 also the same, the area only around 10 meters.
I used deferent wireless clients BB, Windows, CUIC, IPhone, etc
02-28-2012 09:17 AM
what antenna are you using?
Steve
02-28-2012 09:26 AM
for this AP two ports only for 2.4 ,
Dual RP-TNC antenna connectors for 2.4-GHz radios
but I dout in one thing , the2.4GHz antenna for this AP similer to the 5GHz antennas for 1262 AP,, some thing strange
02-28-2012 09:29 AM
what is the part number of the antenna.
02-28-2012 09:47 AM
Product/Model Number: | AIR-AP1242G-E-K9 |
Top Assembly Serial Number: | FCZ1416800X |
System Software Filename: | c1240-k9w7-tar.124-3g.JA1 |
System Software Version: | 12.4(3g)JA1 |
Bootloader Version: | 12.4(13d)JA |
System Uptime: | 1 hour, 15 minutes |
02-28-2012 02:30 PM
Your photo looks kinda wierd. Your product ID is a 1242 but the WAP has only TWO (2) radio antenna sockets instead of FOUR (4).
02-28-2012 09:49 AM
I need to know the part number of the antenna, we know the AP.
Steve
02-28-2012 09:50 AM
Doesn't look like a 2.4ghz antenna if its a Cisco branded one.
02-28-2012 09:51 AM
how can get it ??
02-28-2012 09:52 AM
it should have been on the packing the antenna came in.
02-28-2012 09:55 AM
I dont have it , it is an old setup ,
02-28-2012 09:58 AM
than either your antenna went bad, which can happen. Or it's a 5GHz antenna.
Do you have another 1242 you can take the 2.4GHz antenna off of and test?
Steve
02-28-2012 10:34 AM
can 1242 be G only ??
