AIR-AP1252AG-A-K9 and WPA2 and AES?
William Pearson
I recently purchased this AP used for home use.  I wanted an AP with A/B/G/N.  When I look at the Cisco Sales Page, http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1250-series/product_data_sheet0900aecd806b7c5c.html
It clearly states this access point supports WPA2 and AES.  Yet when I try to configure this in the GUI or in CLI, I don't see these options.  All I get is WEP, and WPA1 if I use a radius server.  What am I missing here?  The documentation page reflects what I am seeing.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-4-25d-JA/Configuration/guide/cg_12_4_25d_JA.html
No examples on configured WPA2 or AES.
I am using  Version 15.2(2)JA1 IOS.
8 Replies 8
Rasika Nayanajith
It should be supported. Here is what you want. Modify  <SSID_NAME> & <PASSWORD> as you like & then plug this to your home DSL router/modem.
conf t
hostname <AP_HOSTNAME>
dot11 ssid <SSID_NAME>
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii <SSID_PASSWORD>
interface Dot11Radio0
 encryption mode ciphers aes-ccm
 ssid <SSID_NAME>
 no shutdown
interface Dot11Radio1
 channel width 40-above
 ssid <SSID_NAME>
 no shutdown
interface BVI1
 ip address dhcp
end
write memory
Rasika
**** Pls rate all useful responses ****
Thank you, that worked perfectly.  But now I am seeing different issues, hopefully you or someone else can help.  Both my Radios are 802.11N, the 2.4GHZ and the 5GHZ.  And neither one has configurable speeds above 54mpbs.  I know N speeds should be much higher than this.  I read on another forum to perform these steps to fix the issue.
1. For encryption only completely open or wpa2/aes will work.
2. On the WLAN, WMM needs to be allowed.
3. antennas are recommended.
4. MCS rates upto 15 should be enabled.
5. Channel bonding can be enabled ( not recommended on the 2.4 GHz channel)
I am now performing step 1.  In the GUI, I found WMM and enabled it.  I have all 6 antennas on the AP.  MCS rates are at 15.  I am not sure about step 5.
int d1
speed ?
12.0        Allow 12.0 Mb/s rate
  18.0        Allow 18.0 Mb/s rate
  24.0        Allow 24.0 Mb/s rate
  36.0        Allow 36.0 Mb/s rate
  48.0        Allow 48.0 Mb/s rate
  54.0        Allow 54.0 Mb/s rate
  6.0         Allow 6.0 Mb/s rate
  9.0         Allow 9.0 Mb/s rate
  basic-12.0  Require 12.0 Mb/s rate
  basic-18.0  Require 18.0 Mb/s rate
  basic-24.0  Require 24.0 Mb/s rate
  basic-36.0  Require 36.0 Mb/s rate
  basic-48.0  Require 48.0 Mb/s rate
  basic-54.0  Require 54.0 Mb/s rate
  basic-6.0   Require 6.0 Mb/s rate
  basic-9.0   Require 9.0 Mb/s rate
  default     Set default rates
  m0-7        Allow MCS rate indices 0-7
  m0.         Allow MCS rate index 0
  m1.         Allow MCS rate index 1
  m10.        Allow MCS rate index 10
  m11.        Allow MCS rate index 11
  m12.        Allow MCS rate index 12
  m13.        Allow MCS rate index 13
  m14.        Allow MCS rate index 14
  m15.        Allow MCS rate index 15
  m2.         Allow MCS rate index 2
  m3.         Allow MCS rate index 3
  m4.         Allow MCS rate index 4
  m5.         Allow MCS rate index 5
  m6.         Allow MCS rate index 6
  m7.         Allow MCS rate index 7
  m8-15       Allow MCS rate indices 8-15
  m8.         Allow MCS rate index 8
  m9.         Allow MCS rate index 9
  range       Set rates for best range
  throughput  Set rates for best throughput
  <cr>
Here is my current config.
version 15.2
no service pad
service password-encryption
hostname HomeAP
logging rate-limit console 9
enable secret 5
no aaa new-model
dot11 syslog
dot11 ssid whzap
   authentication open
   guest-mode
   wpa-psk ascii 7
username Cisco password 7 112A1016141D
bridge irb
 no ip address
 no ip route-cache
 ssid whzap
 antenna gain 0
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 no ip address
 no ip route-cache
 ssid whzap
 antenna gain 0
 dfs band 3 block
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 ip address dhcp client-id GigabitEthernet0
 no ip route-cache
ip http server
ip http authentication local
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
end
How do I get the throughput of 802.11N on the 5GHZ channel or the 2.4GHZ channel?
5. Channel bonding can be enabled ( not recommended on the 2.4 GHz channel) - See more at: https://supportforums.cisco.com/discussion/10932026/cisco-ap-1252ag-cannot-setup-more-54mbs-speed-radio-0-24g#sthash.ESpneBsu.dpuf
You do not require any additional configs, all 5 points you mentioned is included in that config.
Connect your 802.11n client & do the "show dot11 association <client_mac_add>" you would see the connectivity details.
Post that output if you are not sure
Rasika
I do that command and see my client connected.  Then I perform a speed test and get 1-2MB/s download speeds.  I can then go connect to my best buy linksys AP 802.11N and do the same bandwidth test and get close to 20MB/s.
Should the Cisco AP not have a configuration option for speeds higher than 54Mpbs?
This is from the 1252 Data Sheet.  So it seems to me, if my 5GHz Radio is at 40-MHz and using 15 MCS, I should have wireless rates up to 300Mbps.  Yet I still have only the option for 54Mbps.  And the throughput test is way less than 54.  Anyone have any ideas how I can get my 802.11N configured for at least half the speeds it is supposedly capable of?
Data Rates Supported
802.11a: 6, 9, 12, 18, 24, 36, 48, and 54 Mbps
802.11g: 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, and 54 Mbps
802.11n data rates (2.4 GHz and 5 GHz):
MCS Index1
GI2 = 800ns
GI = 400ns
20-MHz Rate (Mbps)
40-MHz Rate (Mbps)
20-MHz Rate (Mbps)
40-MHz Rate (Mbps)
13.5
7.2
15
27
14.4
30
40.5
21.7
45
54
28.9
60
81
43.3
90
108
57.8
120
6
58.5
121.5
65
135
7
65
135
72.2
150
8
13
27
14.4
30
9
26
54
28.9
60
81
43.3
90
11
52
108
57.8
120
12
78
162
86.7
180
13
104
216
115.6
240
14
117
243
130
270
15
130
270
144.4
300
By default these MCS data rate is configured (you do not want to manually configure). So as long as your clients is connect with 5GHz & 40Mz  & capable of two Spatial Stream connection then you should get 300Mbps data rate.
Pls attach "show run" & "show dot11 <client_mac_address>" output to see what's happening.
Rasika
HomeAP#sh run
Building configuration...
Current configuration : 1885 bytes
! Last configuration change at 16:21:42 UTC Mon Mar 1 1993
version 15.2
no service pad
hostname HomeAP
enable secret 5 $1$eSJK$t/MaUCeLSQddN05nElJvB0
no aaa new-model
dot11 syslog
dot11 ssid whzap
   authentication open
   guest-mode
   wpa-psk ascii 7
bridge irb
 no ip address
 no ip route-cache
 ssid whzap
 antenna gain 0
 station-role root
 bridge-group 1
 no ip address
 no ip route-cache
 ssid whzap
 antenna gain 0
 dfs band 3 block
 channel dfs
 station-role root
 bridge-group 1
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
end
HomeAP#
HomeAP#sh dot11 assoc b418.d172.453a
Address           : b418.d172.453a     Name             : NONE
IP Address        : 192.168.1.122
Gateway Address   : 0.0.0.0
Netmask Address   : 0.0.0.0            Interface        : Dot11Radio 1
Device            : unknown            Software Version : NONE
CCX Version       : NONE               Client MFP       : Off
State             : Assoc              Parent           : self
SSID              : whzap
VLAN              : 0
Hops to Infra     : 1                  Association Id   : 1
Clients Associated: 0                  Repeaters associated: 0
Tunnel Address    : 0.0.0.0
Key Mgmt type     : WPAv2 PSK          Encryption       : AES-CCMP
Current Rate      : m7-4               Capability       : WMM 11h
Supported Rates   : 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2
Voice Rates       : disabled           Bandwidth        : 40 MHz
Signal Strength   : -52  dBm           Connected for    : 304 seconds
Signal to Noise   : 44  dB            Activity Timeout : 40 seconds
Power-save        : On                 Last Activity    : 20 seconds ago
Apsd DE AC(s)     : NONE
Packets Input     : 883                Packets Output   : 697
Bytes Input       : 114084             Bytes Output     : 263401
Duplicates Rcvd   : 0                  Data Retries     : 77
Decrypt Failed    : 0                  RTS Retries      : 0
MIC Failed        : 0                  MIC Missing      : 0
Packets Redirected: 0                  Redirect Filtered: 0
Session timeout   : 0 seconds
Reauthenticate in : never
As per this you client connected at 135Mbps (MCS7, 40MHz). See below for reference as well.
