Hi everybody
How many VLANs can be managed with the AIR-AP1252AG-E-K9 APs ? My customer wants to manage 4 VLANs, data, voice, guest and another
Best regards
Solved! Go to Solution.
The device can support 16 different SSID which is equal to 16 VLANs mapped to 16 different SSIDs.. U can use 4 VLANs.. no problem at all.. lemme know if this answered ur question!!
Please dont forget to rate the usefull posts!!
Surendra
Surendra
Hi Surenda,
Thank you for your fast answser. It's the answer to my question.
Thanks a lot.
