AIR-AP1252AG-E-K9 ON WLC-CT5508
jose.macias
HI
We have some isssue related to AIR-AP1252AG-E-K9 we recently bought, and also converted to LAP, but it doesn´t register on the WLC, this WLC already on production with AIR-CAP3502N-A-K9 AP´s.
It seem it´s al about the E (europe) code, but I already tried to add some Europe country code, but finally when confirmed the process it seems all right but not added when check.
Could some helpme to solve this problem, changing the country code to A on the AP or any other way to make the AP´s register on the WLC, the AP´s will be installed on Mexico.
Jose Macias
Scott Fella
You should be able to just add any -E country code in the WLC. You really should obey the rules though because it can get your company in trouble. Mexico should use -N not a -E.
How are you trying to have these APs join, locally or are they in a remote site? That might be the issue you are running into, not really the country code. The 1252's also require more power than the other Cisco APs.
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps5861/product_data_sheet0900aecd80537b6a.html#wp9005314
-Scott
Leo Laohoo
Won't work.  If you purchased an "E" WAP and install the WAP in Mexico (regulatory domain "-A") then the WAP will operate with "-E" frequencies.
I hope you have a good lawyer in Mexico because this is illegal (if you get caught).
Stephen Rodriguez
You can't change the country code on the AP. if you just got the AP and it's going to be installed in Mexico, I'd send it back to the partner and get a -N AP.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
