Mobilty Group and re-authentication
dcarr3311
Level 2
Level 2
Hello All
I have to WLC's a 4402 and 5508   in a mobilty group. they are both running 7.0.116.0. They are configured to use Web Authentication. We are having complaints that Users are having to re-authenticate when moving around the office. My theory is they are moving from one WLC to the other and then requiring to re-authenticate. Is this what others are seeing? and is this working as designed.?
thanks for your help
Dan
5 Replies 5
George Stefanick
yes sounds like it to me
Make sure the mobility groups have all your WLCs in it. Are your aps on both controllers or just one?
AP's are split between both controllers.
Do you have enough room one 1 WLC for all the APs? If so, test your theory.
Did you try changing the IDLE timeouts and the session timeouts
I would do what nikhilcherian posted, because devices in the run state will be able to roam to another wlc (mobility and interface the same) without having to re-authenticate. But like George mentioned, test it out yourself... Don't listen to users:)
-Scott
