AIR-AP1562I-B-K9 unable to connect to Cisco controller 2504
cldimapilis
FYI.. not very experienced but trying to setup AIR-AP1562I-B-K9 to connect to Cisco Controller 2504
getting the following error:
02/18/2020 05:30:49.0500] wired0: link up
[02/18/2020 05:30:49.1000] wired0: started
[*02/18/2020 05:30:49.1563] aptrace_register_sysproc_fn: duplicate registeration
for 'wired'
[*02/18/2020 05:31:04.2672] Resetting wired0 and[02/18/2020 05:31:04.2900] wired
0: stopped
restart DHCP client
[02/18/2020 05:31:06.3800] wired0 emac 1: link up
[02/18/2020 05:31:06.4300] wired0: link up
[02/18/2020 05:31:06.4800] wired0: started
[*02/18/2020 05:31:06.5350] aptrace_register_sysproc_fn: duplicate registeration
for 'wired'
[*02/18/2020 05:31:21.6454] Resetting wired0 and[02/18/2020 05:31:21.6700] wired
0: stopped
restart DHCP client
[02/18/2020 05:31:23.7600] wired0 emac 1: link up
[02/18/2020 05:31:23.8100] wired0: link up
[02/18/2020 05:31:23.8600] wired0: started
[*02/18/2020 05:31:23.9132] aptrace_register_sysproc_fn: duplicate registeration
for 'wired'
[*02/18/2020 05:31:39.0243] Resetting wired0 and[02/18/2020 05:31:39.0500] wired
0: stopped
restart DHCP client
[02/18/2020 05:31:41.1400] wired0 emac 1: link up
[02/18/2020 05:31:41.1900] wired0: link up
[02/18/2020 05:31:41.2300] wired0: started
[*02/18/2020 05:31:41.2922] aptrace_register_sysproc_fn: duplicate registeration
for 'wired'
[*02/18/2020 05:31:56.4031] Resetting wired0 and[02/18/2020 05:31:56.4300] wired
0: stopped
restart DHCP client
[02/18/2020 05:31:58.5100] wired0 emac 1: link up
[02/18/2020 05:31:58.5700] wired0: link up
[02/18/2020 05:31:58.6100] wired0: started
[*02/18/2020 05:31:58.6709] aptrace_register_sysproc_fn: duplicate registeration
for 'wired'
[*02/18/2020 05:32:13.7813] Resetting wired0 and[02/18/2020 05:32:13.8100] wired
0: stopped
restart DHCP client
[*02/18/2020 05:32:14.5661] CRIT-MeshWiredAdj[0][08:4F:A9:0D:3C:58]: Remove as P
arent
[*02/18/2020 05:32:14.5662] CRIT-MeshLink: Link Down Block Root port Mac: 08:4F:
A9:0D:3C:58 BH Id: 0 Port:0 Device:DEVNO_WIRED0
[*02/18/2020 05:32:14.5663] CRIT-MeshWiredBackhaul[0]: Remove as uplink
[02/18/2020 05:32:15.8900] wired0 emac 1: link up
[02/18/2020 05:32:15.9500] wired0: link up
[02/18/2020 05:32:15.9900] wired0: started
[*02/18/2020 05:32:16.0492] aptrace_register_sysproc_fn: duplicate registeration
for 'wired'
Also unable to enable privileged commands and Im in Exec Mode
Any ideas or tips
7 Replies 7
marce1000
                 - FYI  : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvi14641
 M.
I changed the controller to which the AP is connected to, is set to be 1000Mbps full duplex and it still just reboots
I've also set the controller to be a dhcp server and according to the controller its providing the AP an IP address but the AP does not show any IP
Any ideas ?
     >I changed the controller to which the AP is connected to, is set to be 1000Mbps full duplex and it still just reboots
                               - How is the access point connected to the network ?
 M.
topology is AP-->hardwired-->Cisco Controller 2504 PoE (port 4)  and port 1
                   |------>Serial console -> Serial to USB-->Laptop  <-----|
Simple setup, for now, to configure and test.  Basically AP connected to Port 4 and Laptop connected to Port 1.
Rasika Nayanajith
Below messages indicate AP got "mesh image". Unless it is purposely bought with a "mesh" image on it, I would suggest converting it to "Local" mode AP using "capwap ap mode local" CLI command on the AP & then test.
arent
Rasika
*** Pls rate all useful responses ***
Hi Rasika
Thank you for the response, I did do the capwap ap mode local and the unit seems to keep booting up continuously.
Note I have the AP connected directly to the Controller 2504 on the PoE port4 to power it up.  Does the Controller provide enough PoE power?
[02/17/2020 13:34:13.6000] wired0 emac 1: link up
[02/17/2020 13:34:13.6500] wired0: link up
[02/17/2020 13:34:13.7000] wired0: started
[*02/17/2020 13:34:13.7514] aptrace_register_sysproc_fn: duplicate registeration
for 'wired'
[*02/17/2020 13:34:17.8571] Waiting for uplink IPv4 configuration
[*02/17/2020 13:34:22.8582] Waiting for uplink IPv4 configuration
[*02/17/2020 13:34:27.8593] Waiting for uplink IPv4 configuration
[*02/17/2020 13:34:28.8594] Rese[02/17/2020 13:34:28.8700] wired0: stopped
tting wired0 and restart DHCP client
[02/17/2020 13:34:30.9800] wired0 emac 1: link up
[02/17/2020 13:34:31.0300] wired0: link up
[02/17/2020 13:34:31.0800] wired0: started
[*02/17/2020 13:34:31.1266] aptrace_register_sysproc_fn: duplicate registeration
for 'wired'
[*02/17/2020 13:34:35.2325] Waiting for uplink IPv4 configuration
[*02/17/2020 13:34:40.2335] Waiting for uplink IPv4 configuration
[*02/17/2020 13:34:45.2345] Waiting for uplink IPv4 configuration
[*02/17/2020 13:34:46.2346] Resetting wired0 and[02/17/2020 13:34:46.2700] wired
0: stopped
restart DHCP client
[02/17/2020 13:34:48.3500] wired0 emac 1: link up
[02/17/2020 13:34:48.4000] wired0: link up
[02/17/2020 13:34:48.4500] wired0: started
[*02/17/2020 13:34:48.4992] aptrace_register_sysproc_fn: duplicate registeration
for 'wired'
[*02/17/2020 13:34:52.6050] Waiting for uplink IPv4 configuration
[*02/17/2020 13:34:57.6061] Waiting for uplink IPv4 configuration
[*02/17/2020 13:35:02.6071] Waiting for uplink IPv4 configuration
[*02/17/2020 13:35:03.6073] Resetting wired0 and[02/17/2020 13:35:03.6400] wired
0: stopped
restart DHCP client
[02/17/2020 13:35:05.7200] wired0 emac 1: link up
[02/17/2020 13:35:05.7700] wired0: link up
[02/17/2020 13:35:05.8200] wired0: started
[*02/17/2020 13:35:05.8717] aptrace_register_sysproc_fn: duplicate registeration
for 'wired'
[*02/17/2020 13:35:09.9783] Waiting for uplink IPv4 configuration
[*02/17/2020 13:35:14.9794] Waiting for uplink IPv4 configuration
[*02/17/2020 13:35:19.9804] Waiting for uplink IPv4 configuration
[*02/17/2020 13:35:20.9806] Rese[02/17/2020 13:35:20.9900] wired0: stopped
[02/17/2020 13:35:23.1000] wired0 emac 1: link up
[02/17/2020 13:35:23.1500] wired0: link up
[02/17/2020 13:35:23.2000] wired0: started
[*02/17/2020 13:35:23.2472] aptrace_register_sysproc_fn: duplicate registeration
for 'wired'
[*02/17/2020 13:35:27.3531] Waiting for uplink IPv4 configuration
[*02/17/2020 13:35:32.3542] Waiting for uplink IPv4 configuration
If you have a switch (POE+) I would use that.
If same issue I would go with below to reset it one more time via CLI
capwap ap erase all
Rasika
