APs Hardware faulty very frequently
manvik
Level 3
Level 3
We have AP 1850 series APs deployed in the campus, around 300 APs. All those are connected to Cisco POE switches.
Every day at least 2 APs becomes hardware faulty, they don't even power on.
All APs are new one, maybe 1 year old.
Any method to identify why the APs getting faulty everyday. Does Cisco assist in such cases.
10 Replies 10
balaji.bandi
What PoE switches, i have noticed some issue like this 3700 AP connected 3750swithes. (no solution found other than replacement).
BB
Leo Laohoo
@Rich R have previously observed that the 1800 have a high failure rate.
I would recommend contacting TAC and organize to get them RMA-ed before EoL date.
That’s right we’re averaging between 20 and 30 RMA for 1832s every month, and have been for more than a year already. We have many other APs that are older that don’t have failure rates even 10% of that so it’s much higher than normal. Rest assured that Cisco know about this but they decided a field notice was not required and to replace on failure by standard RMA process.
Thanks for the info.
Cisco does not want a "repeat" of the Memory Component Issue & the Clock Signal Component Issue.
I thought the support for hardware replacement under lifetime warranty  is till end of HW support date and not end of life date, is that not correct ?
-hope this helps-
Read the Terms & Conditions of the Cisco Limited Lifetime Hardware Warranty properly and carefully.
It does say "Cisco hardware warranty support will be discontinued on the Last Date of Support (LDoS) published in the product End of Life Announcement" so I think you're right @ammahend
No.  The End-of-Life date is what is followed.
I RMA 3750X up to the End-of-Life date.
"End of life" simply refers to all the milestone dates in the EOL/EOS notice. For 3750-X:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3560-x-series-switches/eos-eol-notice-c51-736139.html
which means the "Last Date of Support:HW" was 31 October 2021 so you should have been able to RMA those until that date?
I will verify that with Cisco SE, if EOL is true then what does it even mean having and end of hw support date, it’s not that TAC can fix a hardware issue.
-hope this helps-
