AIR-AP1815T-E-K9 keeps enabling personal SSID "Cisco-HomeWifi-Fxxx"
XplLiciT
since the last Upgrade of our WLC (C9800-L-F-K9) to 17.6.4 I have the issue that almost all of our Office Extended APs are enabling the Personal SSID which is configured by default.
I disabled them then in the 2.4 GHz and 5 GHz Radio but they keep coming back online.
Did anyone run into the same issue? Does anyone have a suggestion?
marce1000
 - Start with a checkup review of the C9800-L-F-K9 configuration with the CLI command show tech wireless  ; have the output analyzed with :
                                               https://cway.cisco.com/wireless-config-analyzer/
 M.
appreciate your reply. I did not now about this tool until now.
I found out that there is the Provisioning SSID is enabled in the AP Join Profile..
I deactivated this option and voila no more Cisco-HomeWiFi SSID
Thank you for your help
Glad you able to resolve the issue, thank you sharing with community
we mark this as resolved now.
BB
balaji.bandi
not that we aware, before upgrade have you taken the backup of the config ? if so take the backup of new after upgrade and compare.
also use config analyser.
BB
