04-07-2024 10:50 AM
can anybody help me please.
I have an AIR-AP1832I-E-K9 AP its configured to CAPWAP mode always searching for a WLC, but I would like to use it as an "home AP" without any WLC like a stand alone wireless emitter.
AP#sh ver
Processor board ID KWC254208BA
AP Running Image : 17.9.3.50
Primary Boot Image : 17.9.3.50
Backup Boot Image : 17.3.4.40
c591338e9fd755d2dc6255b3c075881d3d94e9ed93d4fbcc1d7623c9fedd0d3346018ede8c631228--More--
7aee00d6b134e34256ec2543cf4d43695d55858169b6d18a5c06e12238c9c9c5a8625b2a5d0466b7--More--
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version : 3829e04455e55538c94489847147a912
NSS FW version : NSS.AK.C.CS-3-fix5
Base ethernet MAC Address : 70:C9:C6:4E:38:30
PCA Revision Number : 01
PCB Serial Number : KWC254208BA
Top Assembly Serial Number : KWC254208BA
Top Revision Number : A0
Product/Model Number : AIR-AP1832I-E-K9
I found a couple of articles how to convert it to mobility express, I downloaded the ME SW but I can not convert it since the AP is not able to recognize the command what is normally used for staring the conversion:
AP#ap-type mobility-express tftp://10.51.11.20/AIR-AP1830-K9-8-10x-185x-0.tar
% Invalid input detected at '^' marker.
Any ideas?
thanks a lot
04-07-2024 11:20 AM
- One possibility is that the AP was used on 9800 controller , where the then installed capwap images no longer provide this command. So then you would first need to install an aireos based capwap image on it , if at all possible.
Basic conclusion : revert to the home market product range for home wifi use , another point being that the model is or was EOL , potentially not offering modern wireless speeds,
M.
04-08-2024 04:46 AM
thanks a lot for advise.
I was checking, these AP’s should be supported until 2027, so they shouldnt be EOL.
Do you think its possible to re-install the AP with an aireos based capwap image? Any clue which one exactly is working with this AP model or how to do it.
thanks
Basic conclusion : revert to the home market product range for home wifi use , another point being that the model is or was EOL , potentially not offering modern wireless speeds,M.
04-07-2024 11:22 AM
- Adding Oh Yeah! Now I see it : AP Running Image : 17.9.3.50 (9800 capwap image)
M.
