AIR AP1832i E K9
achats
I search software Cisco Mobility express for conversion AIR AP1832i E K9 to Standalone , it is possible with this firmware AIR-AP1830-K9-8.2.141.0.tar and AIR-AP1830-K9-ME-8-2-141-0.zip ?
But i don't have access to download this firmware... I have 3 AP 1832i for my last customer....
Best regards
5 Replies 5
Leo Laohoo
There is no more "autonomous" IOS.  It is either Mobility Express or controller-based IOS.  The "autonomous" concept has been replaced by the Cisco Mobility Express.
Tkank you, I look for the firmware Cisco Mobility Express because it is not possible to download firmware on the cisco website without ID PARTNER CISCO
Can you help me to find firmware with Cisco Mobility Express ( AIR AP1832i E K9) ?
The AP itself contacts the two different image.  It is a question of entering the command to instruct the AP to boot either the CMEx or controller-based IOS.
Read THIS.
Yes but i don't download AIR AP1802i.tar with Mobility Express, do you send the file ?
Sorry , this firmware is on AP, ok i check conversion with command line
thank you
