08-18-2021 04:04 AM
hi,
i got a problem is there any way to configure ( air-ap1832i-i-k9 ) without a console or controller
08-18-2021 04:13 AM
yes you can but that 1832iAP should have a Mobility express image on it.
Dont forget to rate helpful posts
08-18-2021 06:00 AM - edited 08-18-2021 06:48 AM
Many previous questions about this which would have provided the answers if you had searched but here you go:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/user_guide/b_ME_User_Guide_810/getg_started.html#task_7588F4C009744AEFBB9EB754A713E390
This guide written for 1852 but same process applies to 1832 and they both run the same ap1g4 image just the filename you download from Cisco will be different - https://www.cisco.com/c/en/us/support/docs/wireless/mobility-express-aironet-access-points/215410-convert-capwap-1852-access-point-ap-to.html
