AIR-AP1832I-S-K9 Auto reboot
I am trying to convert AP1832 from the CAPWAP version to a Mobility Express. I have the new software in a TFTP server, but when I console to the AP I can´t type AP#ap-type mobility-express tftp because it seems to be in a common state. When it starts up, I have to hit ESC because if not it reboots:
U-Boot 2012.07 (btldr release 30) (Mar 03 2017 - 19:13:24)
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM: 1 GiB
NAND (ONFI): Detected SPANSION S34MS02G2 [256 MiB]
SF: Detected Macronix MX25U3235F [4 MiB]
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[1:0], write_counter=3
PCI0 Link Intialized
PCI1 Link Intialized
Net:
PHY ID = 0x4dd074, eth0 found AR8033 PHY
PHY ID = 0x4dd074, eth1 found AR8033 PHY
Valid I2C chip addresses: 51 52
AP 1832/1852 detected...
Power Type: 802.3at POE detected...
Signature returns 0
BL signing verification success, continue to run...
Auto boot mode, use bootipq directly
Hit ESC key to stop autoboot: 0
(RNAQ-C7) # ?
? - alias for 'help'
base - print or set address offset
bootipq - bootipq from flash device
chpart - change active partition
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
echo - echo args to console
env - environment handling commands
ethreg - ethreg - Switch/PHY Reg rd/wr utility
exit - exit script
false - do nothing, unsuccessfully
go - start application at address 'addr'
help - print command description/usage
i2c - I2C sub-system
iminfo - print header information for application image
imxtract- extract a part of a multi-image
ipq_nand- Switch between SBL and Linux kernel page layout.
loadb - load binary file over serial line (kermit mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mii - MII utility commands
mm - memory modify (auto-incrementing address)
mtdparts- define flash/nand partitions
mtest - simple RAM read/write test
mw - memory write (fill)
nand - NAND sub-system
nm - memory modify (constant address)
pci - list and access PCI Configuration Space
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
printmfgenv- Print manufacture information data
printshenv- printshenv- print shared environment variables
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
saveshenv- saveshenv - save shared environment variables to persistent storage
setenv - set environment variables
setshenv- setshenv - set shared environment variables
sf - SPI flash sub-system
showvar - print local hushshell variables
smeminfo- print SMEM FLASH information
source - run script from memory
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true - do nothing, successfully
ubi - ubi commands
usb - USB sub-system
verify_bl- Cisco Bootloader signature verify
verify_lx- Cisco Image signature verify
version - print monitor, compiler and linker version
(RNAQ-C7) #
0 Replies 0
