11-13-2017 09:51 PM - edited 07-05-2021 07:51 AM
hi all
i have about 10 AIR-AP2802I-A-K9 and a WLC 5508 with software version 8.2.151.0.
all the AP's are joined and working but the performance (download, upload speed) are very poor and never going more than 2-3 mb/s. i must say i have some 1700 series in that controller and they work great!
any suggestions?
Solved! Go to Solution.
11-13-2017 11:57 PM
@reza-koohi wrote:
datarate is about 2-3 mb/s
Disable data rates from 1- to 11 Mbps. Make 12 Mbps Mandatory and the rest are Supported. Do this to both 802.11a and 802.11b radio.
@reza-koohi wrote:
the speed is good in coverage of the 1700 models. its not acceptable in the area the 2802s are covering
Each AP model behaves differently. What if you've got an iPhone 4 and you were connected to 802.11b plus you've got co-channel interference.
11-13-2017 11:17 PM
What is the data rates was the wireless client connected to?
What radio was the wireless client connected to?
What is the model of the wireless NIC of the client and what is the driver of the wireless NIC running on?
11-13-2017 11:43 PM
11-13-2017 11:57 PM
11-14-2017 07:18 PM
thanks
let me check and i will send back the results.
