AIR-AP2802I-B-K9 - setting up issue
helpdesk155
We have purchased the AIR-AP2802I-B-K9
I have plugged it into our switch
switchport trunk native vlan 202
switchport trunk allowed vlan 3,202
switchport mode trunk
When it connects we get
We can not get to the gui only cli with putty serial (console)
active version 8.2.121.0
ethernet_port wired0, ip 172.16.4.166, netmask 255.255.240.0, gw 172.16.8.1, mtu 1500, bcast 172.16.15.255, dns1 172.16.1.53, dns2 172.16.2.53, domain xx.xxx-xx.xx.xxwaiting for POE negotiation to complete
Discovery Request sent to 255.255.25[12/19/2016 01:09:16.4200] device capwap0 entered promiscuous mode
5.255 with discovery type set to CAPWAP_DISCOVER[12/19/2016 01:09:16.5500] device capwap1 entered promiscuous mode
Y_TYPE_UNKNOWN(0)
Interface IP-Address Method Status Protocol Speed
wired0 172.16.4.166 DHCP up up 1000
wired1 unassigned unset down down n/a
wifi0 unassigned unset administatively down down n/a
wifi1 unassigned unset administatively down down n/a
Leo Laohoo
There is a possibility the AP is running the controller-based IOS (default behaviour).
To convert from controller-based IOS to Mobility Express, read THIS.
I have tftp32 on my machine.
I can ping my machine from the ap
I type
archive download-sw /reload tftp://172.16.4.167/c:\tftp\AIR-AP2800-K9-ME-8-3-102-0.tar\ap1g4
and get the following:
curl: (68) getpeername() failed with errno 107: Transport endpoint is not connected
transfer command failed
Image transfer failed
That command syntax is incorrect.  It should be "archive download-sw tftp://172.16.4.167/filename.tar"
