AIR-CAP 1800/2800 vs 1700/2700
johnlloyd_13
Level 9
Level 9
hi,
i'm comparing the AIR-CAP x800 vs x700 series AP and found this link.
https://supportforums.cisco.com/discussion/12689091/ap-1850-vs-2700
is it just clean air not supported on the 1800/2800 series AP?
any other major difference between the two?
which is the 'go to' AP to deploy? x800 or x700?
Tausif Gaddi
Please refer
Access Points AP 1700 AP 1800 AP 2700 AP 2800
Target Deployment Small or midsize enterprise Small or midsize enterprise Midsize enterprise Midsize to large enterprise with advanced features
Max PHY Data Rate (5GHz) 870 Mbps 1.7 Gbps 1.3 Gbps 5 Gbps
RF Design (MU-MIMO) 3x3:2, Dual SU-MIMO 4x4:4, SU-MIMO
4x4:3, MU-MIMO
3x4:3, Dual SU-MIMO 4x4:3 MU/SU-MIMO
Performance/Coverage/
Investment Protection
Max No. of clients per AP  400 400 400 400
RRM
High Density Experience
Cisco CleanAir Techonology Cisco CleanAir Express Spectrum Analysis
Beam Forming Tx BF Tx BF Cisco ClientLink 3.0 ClientLink 4.0 and Transmit Beam Forming (Tx BF)
Band Select
Video Stream
Rogue AP Detection
Adaptive wIPS
External Antenna Option
Ethernet Ports 2 x GbE 2 x GbE 2 x GbE 2 x GbE
LAG Support
USB
Wi-Fi Standards 802.11 a/b/d/g/n/h 802.11a/b/g/n/acW2 802.11 a/b/g/n/ac 802.11a/b/g/n/acW2
Number of Radios Dual-band radios (2.4 GH
z and 5 GHz)
Dual (2.4GHz and 5.0GHz) two 2.4-GHz/5-GHz dual-band radios Dual (XOR and 5 GHz)
Power Options 802.3af, 802.3at PoE+, Enhanced PoE AC/DC, 802.3at PoE+, Enhanced PoE
802.3af (reduced functionality, USB & AUX port disabled, 1852e 2.4GHz reduced to 3x4)
802.3at PoE+, Enhanced PoE 802.3at PoE+
Limited lifetime warranty
Leo Laohoo
Once the IOS for the 1800/2800/3800 stabilizes, Cisco is going to announce the RMA for the 1700/2700/3700.
If you look at the Release Notes for 8.2 and 8.3 you'll see the list as long Chinese take-away menu about bugs for the 1800/2800/3800.
I am not sure about others but all of my 2800 are still in the box.  I am still deploying 3700 until all my stocks are exhausted.
Tausif Gaddi
Please refer
4x4:3, MU-MIMO
RRM
Band Select
Video Stream
Rogue AP Detection
Adaptive wIPS
LAG Support
USB
z and 5 GHz)
